I’m not sure if this is a bug or intended behavior, but essentially I am having an issue when a call comes in as +1NXXNXXXXXX and ends up leaving a voicemail, the user cannot listen to the voicemail. I’ve posted the call log of what happens when a user tries to listen to one of these voicemails.
To fix it, I have to edit the msg0000.txt and remove the + from the callerid value.
[2025-04-21 08:56:07] VERBOSE[19825][C-00006325] pbx.c: Executing [*97@from-internal:118] VoiceMailMain("PJSIP/300-0000fd7e", "300@default") in new stack
[2025-04-21 08:56:07] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-password.ulaw' (language 'en')
[2025-04-21 08:56:11] VERBOSE[19825][C-00006325] res_rtp_asterisk.c: 0x7efc3849b220 -- Strict RTP learning complete - Locking on source address CUSTOMER_WAN_IP:16484
[2025-04-21 08:56:12] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-youhave.ulaw' (language 'en')
[2025-04-21 08:56:13] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'digits/4.ulaw' (language 'en')
[2025-04-21 08:56:13] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-INBOX.ulaw' (language 'en')
[2025-04-21 08:56:14] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-and.ulaw' (language 'en')
[2025-04-21 08:56:15] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'digits/1.ulaw' (language 'en')
[2025-04-21 08:56:16] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-Old.ulaw' (language 'en')
[2025-04-21 08:56:17] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-message.ulaw' (language 'en')
[2025-04-21 08:56:18] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-onefor.ulaw' (language 'en')
[2025-04-21 08:56:19] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-first.ulaw' (language 'en')
[2025-04-21 08:56:20] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-message.ulaw' (language 'en')
[2025-04-21 08:56:21] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-received.ulaw' (language 'en')
[2025-04-21 08:56:22] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'digits/day-3.ulaw' (language 'en')
[2025-04-21 08:56:23] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'digits/at.ulaw' (language 'en')
[2025-04-21 08:56:24] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'digits/8.ulaw' (language 'en')
[2025-04-21 08:56:24] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'digits/50.ulaw' (language 'en')
[2025-04-21 08:56:26] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'digits/a-m.ulaw' (language 'en')
[2025-04-21 08:56:27] VERBOSE[19825][C-00006325] file.c: <PJSIP/300-0000fd7e> Playing 'vm-from-phonenumber.ulaw' (language 'en')
[2025-04-21 08:56:29] WARNING[19825][C-00006325] file.c: File does not exist in any format
[2025-04-21 08:56:29] WARNING[19825][C-00006325] file.c: Unable to open (format (ulaw)): No such file or directory
[2025-04-21 08:56:29] VERBOSE[19825][C-00006325] pbx.c: Spawn extension (from-internal, *97, 118) exited non-zero on 'PJSIP/300-0000fd7e'
[2025-04-21 08:56:29] VERBOSE[19825][C-00006325] pbx.c: Executing [h@from-internal:1] Macro("PJSIP/300-0000fd7e", "hangupcall") in new stack
[2025-04-21 08:56:29] VERBOSE[19825][C-00006325] pbx.c: Executing [s@macro-hangupcall:1] GotoIf("PJSIP/300-0000fd7e", "1?theend") in new stack
[2025-04-21 08:56:29] VERBOSE[19825][C-00006325] pbx_builtins.c: Goto (macro-hangupcall,s,3)
[2025-04-21 08:56:29] VERBOSE[19825][C-00006325] pbx.c: Executing [s@macro-hangupcall:3] ExecIf("PJSIP/300-0000fd7e", "0?Set(CDR(recordingfile)=)") in new stack
[2025-04-21 08:56:29] VERBOSE[19825][C-00006325] pbx.c: Executing [s@macro-hangupcall:4] Hangup("PJSIP/300-0000fd7e", "") in new stack
[2025-04-21 08:56:29] VERBOSE[19825][C-00006325] app_macro.c: Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'PJSIP/300-0000fd7e' in macro 'hangupcall'
[2025-04-21 08:56:29] VERBOSE[19825][C-00006325] pbx.c: Spawn extension (from-internal, h, 1) exited non-zero on 'PJSIP/300-0000fd7e'
I’ve made my trunks use from-pstn-e164-us as a workaround but the voicemail is the only thing I’m having an issue with. If it’s a bug, I’ll file a bug report.
