I have some dialplan to monitor S/S signatures for incoming calls. At this point I’m not doing anything other than recording in the CDR. If patterns emerge with problem calls, someday I will use the attestation history to figure out filtering.
[from-pstn-check-ss]
exten => _.,1,Noop(Entering user defined context from-pstn-check-ss in extensions_custom.conf)
exten => _.,n,Set(CALL_ATTESTATION=${PJSIP_HEADER(read,X-Twilio-VerStat)})
exten => _.,n,NoOp(S/S Attestation Level: ${CALL_ATTESTATION})
exten => _.,n,ExecIf($["${CALL_ATTESTATION}"!=""]?Set(CDR(userfield)=S/S Level ${CALL_ATTESTATION}):Set(CDR(userfield)=S/S Level Unsigned))
exten => _.,n(inroute),Goto(from-pstn-e164-us,${EXTEN},1)
; end
I’m going to put this out there like I have in other places. Using only the attestation for determining the validity of the call is not the way to go. There are quite a few of prolific spam carriers that will mark a call with an A attestation because it meets the requirements. The call originated on their network, with their DID from their customer which results in an A attestation. The call is still about your SSN being revoked unless you pay a “fine”. Onvoy is one of the biggest prolific spam carriers out there and pretty much all their calls get signed with an A attestation.
So at the end of the day, you could receive numerous calls with an A attestation and all be scam/spam/fraud calls and you could receive legit calls with a B or even no attestation. S/S is about the relationship between the OSP (originating provider), the CallerID presented and the subscriber presenting the call with said CallerID. It has no bearing on the contents of the call.
100% agree with you. The customer was adamant they wanted to block all C so we just provided dialplan for them and thought it was good to share with others as a foundation.
I don’t disagree with that at all. The dialplan is helpful. Using the attestation as part of the overall logic makes sense. Using it as the only logic, not so much.
A month or so ago, we had an XCast Labs customer request all unsigned calls be blocked at the trunk switch, which was done. It remained enabled only for a few days before they requested we revert the block and only apply it to select DIDs.
Monitoring signatures seems like a safer way to proceed.
TangoPBX is a trademark of TangoPBX LLC, FreePBX is a trademark of Sangoma US Inc, Asterisk is a trademark of Digium Inc.
