New PR is ready for review
Hi Everyone.
How are you?
I pushed 4 PR for the following modules:
First:HotelWakeUp module You can program multiple alarms simultaneously for an extension.
Second: CDR module modernized so 2 PR (16 and 17).
Third: My gateway module, which I would also like to see published.
Franck
I remember seeing some of your early work on the CDR, forgive the ignorance. How do we go about, implementing to a FreePBX 17 system?
Hi.
Well, I’m trying to get someone from Sangoma to release it on 17.
For now, it looks like it’s published for 18.
I’m praying that versions 17 and 18 will be released on EDGE.
Stay tuned, and check Edge version as possible.
HotelWakeup is released on 17.
Regarding gateway module, Need wait Sangoma to approve it.
@franck.danard you rock!
Tsss. I’m pissed off.
No pull requests approved, so no modules published. I wonder if the team really wants to improve FreePBX
I’m disappointed.
Boo, I am sorry to hear this @franck.danard. I feel like they want it to improve in areas they can monopolize.
Maybe indeed.
I don’t know exactly.
Your changes for wakeup calls in v17 was merged Aug 24th. As for all the v16 based stuff…well v16 hit SFO on Sept 1st 2026. Only security fixes and commercial improves are now accepted after that date.
I get it, they should have handled those a lot sooner but at this point with v16 going EOL in 2.5 months I doubt any outstanding v16 PRs are going to be touched.
No, If there is a version for 16, it can be used for 17 as well.
Usually, the team could merge it for both.
All modules are compatible for 17 too.
Maybe there is an exception for CDR modernized. It could be used for 18.
That’s not entirely true. v16 is PHP 7.4 and v17 is PHP 8.2 and there are a lot of things that need to be checked when moving from 7.4 to 8.2+. As pointed out in your PR requests there’s issues even in the v16 version and while in PHP 7.4 those issues will either throw warnings (surpressed or not) or nothing at all but in PHP 8.2 they will throw hard errors and warnings and nothing will work.
So there is no guarantee that something written for v16 will work in v17 unless the author went through and painstakingly made sure it was 100% forward compatible with PHP 8.2+.
