Network Setup Help – Dual Ethernet Ports with SIP Trunk
Hi all,
I’m new here and setting up a FreePBX v17 server and could use some guidance on configuring a dual Ethernet port setup, particularly around networking and firewall rules.
Here’s the setup:
eth0:
  • Connected to the main network and assigned the IP address 10.0.0.254.
  • Has a public IP address mapped through the firewall – this is used for the Gamma SIP trunk, which relies on IP-based authentication.
  • I need inbound and outbound SIP calls to route correctly through this interface to the FreePBX server.
  • I also want to access the FreePBX Web UI and SSH via this port.
  • Since this port is connected to the internet, I want to lock it down and ensure only the necessary services and ports (e.g., SIP, RTP, Web UI, SSH) are exposed.
eth1:
  • Connected to an isolated PoE switch that hosts all the IP phones.
  • This network runs on the 192.168.0.x subnet, with the server using 192.168.0.1 on this port.
  • All endpoint phones will have static IPs.
What I need help with:
  1. Network configuration: How to correctly configure the two interfaces so that SIP calls can route between the SIP trunk on eth0 and the phones on eth1.
  2. Firewall rules: What kind of rules should I implement to:
  • Allow SIP trunk traffic in/out via eth0
  • Allow internal phone registration and media traffic on eth1
  • Restrict all unnecessary ports on eth0 to improve security
  1. Any tips or best practices for a setup like this, especially in terms of securing the system and ensuring reliable call routing.
Any help or examples would be greatly appreciated!
Thanks in advance!
Why not use VLAN since you are using 2 different subnets
Are you using sysadmin to setup the networks?
No, i’m planning to just do a new fresh installation of Debian 12 and then install freepbx 17 on it. And then configure the network interfaces as mentioned above. from what I understand, freepbx has it’s own firewall but this isn’t enabled by default and debian too has it’s own iptable or some sort of firewall which i am not sure if that’s enabled by default or not. Not sure if i should be enabling the freepbx firewall or lockdown the debian one further. Need help :slight_smile:
I asked Chatgpt and this is the detailed guide it provided me. Does this sound right? is there anything specific I should do with firewall to protect eth0 from unwanted traffic since eth0 is public firewall facing as I only want eth0 to provide sip trunk for incoming and outgoing calls, ssh, web ui
Step 1: System Prep and Interface Configuration
A. Assign Static IPs
Edit /etc/network/interfaces (or /etc/netplan/*.yaml on newer Debian versions — use ip a to check interface names):
For Debian 12+, likely using Netplan. Example /etc/netplan/01-netcfg.yaml:
network:
  version: 2
  renderer: networkd
  ethernets:
    eth0:
      dhcp4: no
      addresses:
        - 10.0.0.254/24
      gateway4: 10.0.0.1
      nameservers:
        addresses: [8.8.8.8, 1.1.1.1]
    eth1:
      dhcp4: no
      addresses:
        - 192.168.0.1/24
Then run:
sudo netplan apply
:white_check_mark: eth0 = External (Internet + SIP trunk)
:white_check_mark: eth1 = Internal (Phones)
Step 2: Enable and Configure the FreePBX Firewall
FreePBX has its own intelligent firewall which understands VoIP-specific traffic better than plain iptables/UFW.
A. Enable the FreePBX Firewall
From the FreePBX web GUI:
  1. Go to Admin > System Admin > Firewall
  2. Click Enable Firewall
B. Define Zones:
  • eth0 → Internet zone
  • eth1 → Trusted/Internal zone
To do this:
  1. Go to Connectivity > Firewall > Interfaces
  2. Assign:
  • eth0 → Internet
  • eth1 → Trusted
C. Services
Go to Connectivity > Firewall > Services:
Allow only these on Internet:
  • SIP (chan_pjsip or chan_sip) — depending on what you’re using
  • RTP Ports (usually UDP 10000–20000)
  • HTTPS (for Web UI, or HTTP if not using SSL)
  • SSH
Do NOT allow:
  • WebRTC
  • TFTP
  • NTP
  • Rest APIs
  • UCP
  • Admin (unless you really need it remotely)
Step 3: RTP and SIP Port Configuration in FreePBX
SIP Settings
  1. Go to Settings > Asterisk SIP Settings
  2. Under General SIP Settings:
  • External Address: your public IP (or FQDN)
  • Local Networks:
    • 10.0.0.0/24
    • 192.168.0.0/24
RTP Ports
Still in SIP Settings:
  • RTP Port Range: leave default 10000–20000 unless restricted
  • Ensure router/firewall has these UDP ports forwarded to 10.0.0.254 (eth0)
Step 4: Configure iptables/UFW (optional)
While FreePBX’s firewall is solid, you may want to harden Debian’s native firewall too. If you use UFW (simpler than iptables), here’s a base config.
A. Install and Configure UFW:
sudo apt install ufw
sudo ufw default deny incoming
sudo ufw default allow outgoing
Then allow only essential ports:
# SIP (change ports if needed)
sudo ufw allow from any to 10.0.0.254 port 5060 proto udp
sudo ufw allow from any to 10.0.0.254 port 5061 proto udp
# RTP
sudo ufw allow from any to 10.0.0.254 port 10000:20000 proto udp
# Web UI
sudo ufw allow from your_admin_ip to any port 443 proto tcp
# SSH
sudo ufw allow from your_admin_ip to any port 22 proto tcp
Then enable it:
sudo ufw enable
:stop_sign: Note: If using FreePBX firewall, ensure UFW doesn’t block it. It’s usually safest to let FreePBX manage traffic if you’re not very experienced with iptables.
Step 5: Test Your Routing and SIP Path
A. Phones (Internal) ➝ FreePBX ➝ SIP Trunk
  • Register a few phones to FreePBX from the 192.168.0.x network
  • Test internal calls
  • Test outbound SIP calls
B. External ➝ SIP ➝ FreePBX ➝ Phones
  • Make an inbound call to your public number (via Gamma SIP)
  • Verify call lands on a local phone
Step 6: Best Practices
:white_check_mark: Disable unused FreePBX modules and admin interfaces
:white_check_mark: Enforce strong FreePBX passwords (Admin + Extensions)
:white_check_mark: Regularly apply Debian and FreePBX updates
:white_check_mark: Set up intrusion detection (Fail2Ban is included in FreePBX firewall)
:white_check_mark: Optional: Disable SIP guest access (no anonymous calls)
Isn’t the system behind a firewall already? How are you reaching the PBX over the Internet to begin with?
Yes it’s already behind a hardware firewall which has a 1:1 Nat to give the server a static ip for siptrunk ip authentication.
So why wouldn’t you just apply the rules there for the wan side?
VLANs are your friend for a setup like this. Using a switches and a firewall/router to keep everyting secure. I normally use a dual NIC setup for carrier SIP trunking. eth0 for internal phones network using VLANs. eth1 as a connection for the carrier’s CPE SBC.
