IAX multiple systems DID
We’ve got a system that is considered “master” on a campus that has upstream trunks, previously multiple buildings just had extensions, but now a directive has come out that several of these buildings should operate their own pbx.
OK, no problems, all setup, working, they can make outbound calls by master-pbx being set as default outbound. so far all good.
Last night they came to us and want a band of inbound routes (previously they never took outside calls), this is something I’ve never done before with IAX, from the pretty much useless documentation I can find, its a mater of inbound routes on master-pbx to internal-pbx-trunk-1,2,3,4 etc. this worked on my 2 test numbers, but I’ll be damned if I’m going to sit there and type our several hundred :slight_smile:
MY question is, is there an easier way? I am thinking of setting inbound route and trying
DID:   _61775531[8]xx    to DEST trunk-bld2
DID:   _61775531[9]xx    to DEST trunk-bld3
I’ve only used the regex in CID before so not sure if it is even recognised in DID and before I try this and pixx a lot of people off if it doesn’t work and collapses the system, any thoughts on this approach from someone who HAS done this in practise (not only in their head/on paper)? any gotchyas I need to be aware of assuming it works, or is there an entirely different way?
please note, the actually numbers have been slightly changed to protect the guilty :wink:
and I think I’ve been around unix too long… of course I meant IAX /sigh/
That should work just fine, I have a lot of my school districts set up that way. :slight_smile:
Awesome, thanks @Taylor, I’ll be implementing this on Sunday night all things going to plan.
(I also realise I don’t need square brackets around the 9, the 8 we do because it’s joined by another number :slight_smile:
or, to be correc,t even IAX2
tomaytoes / tomartoes :stuck_out_tongue:
Works well, very painless.
IAX2 is right, righteous and correct.
You can of course write AIX, IAX, tomaytoes or tomartoes, but they are all wong, wrong, biblically wicked and incorrect. We all no that if you dial the wong number you might get a state sponsored agent in the far east :wink:
and in the west too, just a different spook will process your call, actually, even if you get the right number they “process” your call lol
