Freepbx and Clearly ip
I have a Freepbx 17 with some clearly ip registered too this Freppbx. Raspatory was set to clearlyip And I did module upgrade on this pbx and logo is Clearly ip now. How can I change it back to Freepbx? Tried fwconsole setting MODULE_REPO https://mirror.freepbx.org and upgraded modules again , I see same logo. What modules need to be updated to show freepbx logo?
If you want the Fpbx stuff back you simply uninstall the clearly ip module in module admin. Your PBX will change back to Gestapo Green, and the fpbx logos will be restored.
I have two clearly ip modules, ClearlyIp and clearly device. Which one? And I have to re add all the phones, after restoring the freepbx logo and re installing clearly ip. Correct?
Remove ClearlyIP Module, No you will not lose the phones or provisioning. Clearly Devices manages all that, which is why you keep it.
Thanks! I will remove it
Clearly, you haven’t seen the light :slight_smile: anyway - good to see you hear, and I hope you are doing well
@ChrisD lookin’ good buddy! Hope you are doing well also, but it looks like you are =)
Checked in on the scale this morning, officially down 100lbs today! When I think about two full 50lb suitcases gone, it’s nuts - thank you.
