Enabling MFA on the TangoPBX Forum
First thing I do when I create a user account is look for the ability to enable MFA, then I silently judge you if it’s not a option. Luckily, MFA is available here on the TangoPBX forum.
After logging in, click your avatar in the upper right, and select Profile
from there, click preferences, and then security from the menu options horizontally along the top. On this page you can enable the MFA option of your choice.
Already set mine up - I was glad to see the forum offers passkeys!
weirdest looking backup codes I’ve seen, look more like SHA hashes, did something go awry ?
The library I’m using for a project generates its own codes and I think there’s six digits long or 10 digits I don’t recall
Hi James, Yeah, all my backup codes from various forums give me 10 digits, its no drama, just checking its meant to be the way it is here, since I rather not waste one of my codes just to test :slight_smile:
