Discord for TangoPBX?
Will there also be a Discord for Tango PBX like there is for Crosstalk Solutions??
My goal is to get a Functional PBX running up in my room hopefully either over Wi-Fi or Internet. But I have no access to my router.
Doubtful you’d be able to do this with any outbound calling, as you’ll need to NAT SIP from your provider to your PBX, which without access to the router you can’t do to my knowledge.
If you do auth with a user/pass, you should be able to.
Yes I am aware of that. And I can’t connect to Wi-Fi either because my system isn’t activated and I don’t have that options in System Admin. I even tried it in console. I got nothing with lo-cfg
