Dial Plan Vizualizer 1.0.27 Released
:rocket: Big update to the FreePBX Dial Plan Vizualizer module!
This release adds a bunch of quality-of-life features and visual improvements to make managing dial plans and extensions a lot smoother:
  • :blue_circle: Dynamic queue member login status is now displayed.
  • :yellow_circle: See Asterisk DND / Call Forward status at a glance.
  • :pause_button: Queue pause status detection included.
  • Tooltips now show user agents and voicemail counts.
  • Consistent tooltips across queues, ring groups, and extensions.
  • Added Next / Previous buttons for dialplan navigation (works with search!).
  • Extensions now appear in the dialplan dropdown.
  • New options: Allowlist, Blacklist, and Auto-play audio.
This should make it easier to visualize what’s really going on in your PBX and speed up troubleshooting.
Installation / upgrade: https://github.com/madgen78/dpviz
Previous releases: https://github.com/madgen78/dpviz/releases
Let me know what you would like to see next.
Thanks for all of the support and suggestions. - and if you’d like to keep up with future updates, consider :star: starring or following the project on GitHub.
  • Adam
Thank @madgen, for anyone that is reading this that has not installed this tool… go get it. It is a game changer.
@madgen Excellent f*cking work! Really great tool!!
Installed on fpbx 17, looks good, thanks, deftly worth installing :slight_smile:
Version 1.0.28 Released!
  • Faster graph rendering with optimized code for better performance.
  • Unified node style: all nodes now use rounded rectangles for a cleaner, more consistent look.
  • Refined tooltips with improved styling for readability.
  • IVR grouping: identical selection destinations are grouped together, reducing cluttered lines.
  • Simplified IVR nodes: Conferences, DISA, and Feature Codes are now displayed inside the IVR node instead of separate nodes.
  • Inbound routes dropdown option:
    • New setting to display destinations in the inbound routes dropdown.
    • Automatically disabled on install if you have more than 100 inbound routes (can be re-enabled).
    • Helps reduce initial module load time on larger systems.
1.0.30 has been released!
  • Added “In Use By” visualization
    • Nodes are now drawn if their destination points to the selected dial plan.
    • Extensions will show if they are static or dynamic agents of Queues and Ring Groups.
    • Will also show when a destination is not used.
    • Disabled by default; enabling may introduce a very slight delay.
  • Resolved “Tampered Files” error on FreePBX 17.
  • Fixed Time Conditions calendar matching bug.
