The bulkVS stuff is not dynamic location. They are just dynamically sending address line 2. But the call back number and address is identical on each call from every room. So now if 911 calls back all they get is the main number to call back so the call is not routed back to who actually called 911.
Well I guess that’s no good then.
If it were me, I would create a ghost extension to use in building B. Lets say he is extension 105, I would create extension 6105 with the Caller ID set the same as x105 and the emergency CID set to match his actual location. Then go in 105 and setup a Find-Me-Follow-Me to allow 105 and 6105 to ring at the same time. Next setup x6105 with a voice mail key if needed to watch x105’s VM box. He will only let people know of x105, the ghost extension will only be their to let the system know where the 911 call is coming from. Hope this helps!
-Patrick
